VPN config
We have two sites one in dubai office another one is London office,somebody calls from London office it shouted routed through VPN
Is this possible task?
  • IP Telephony
VPN config
You mean should, instead of shouted???
You don't provide enough info, is there a CUCM in each office?? CoW?? Different clusters??
Centralized CUCM??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
VPN config
Jaime,
Both sites are CUCM,its not centralized running on different clusters.
As far i know when network is reachable between both sites there is not issue on routing call
My Requirements
When the Make a extension call from London office to Dubai its applying as a international call, Users From London make a call it should routed via VPN tunnel?
As i know that we can create a sip trunk between sites so that they can communicate internall calls,
I am confused on how we can route through vpn tunnel?
Re: VPN config
What technology you use is irrelevant in the end, it doesn't change at all the config.
Configure either a SIP trunk, or ICT (depending on your versions), and configure the call routing between the clusters. That's all you need.
EDIT: Bear in mind that aside from the CUCM config, you'll need to make sure there's end to end connectivity for the endpoints thru your VPN so calls work.
java
java
111
