::: VSPT :::
Urban_Nights
Hi people,
when I am trying to connect to a MGC via VSPT I receive an error.
It seems that the connection is refused.
Can you please help me with the attachs?
Regards and thanks.
irisrios
Level 6
Level 6
VSPT Release 2.2 is designed to be used with Cisco MGC software Release 9.2. If you are using an earlier release of the MGC software, you must use VSPT Release 1.6 or 2.1. VSPT Release 2.1 is designed to be used with Cisco Media Gateway Controller Software Release 9. If you are using an earlier release of the MGC software, you must use VSPT Release 1.6.
http://www.cisco.com/en/US/docs/net_mgmt/vspt/2.2/vspt22ov.html
irisrios
Level 6
Level 6
Thank you!
I am using MGC 9.7(3).
Regards and thanks.
