VIP Super Bronze
VT Advantage: Video Calls over Wan to different Cluster
I want to know if its possible to make a Video call (VT advantage) to another callmanager cluster with VT advantage...
This is the scenario..
CCM6.1.1 with Vt advantage>>>IP WAN>>>CUCMBE with VT advantage.
Can this work?
If so what configs do I need to enable on the Voice gateway..
NB: Video calls work ok internally in both clusters
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
1 ACCEPTED SOLUTION
Re: VT Advantage: Video Calls over Wan to different Cluster
You should be able to configure an intercluster trunk between the 2 systems that will send calls over the wan, which will allow you to make video calls. Also, be aware of your bandwidth usage. CAC is recommended.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/4x/42trunks.html
1 REPLY
161
