VWIC is showing as "WIC module not supported/disabled in this slot"
Hello All,
please help me on this asap!!
Smart Init is enabled
smart init is sizing iomem
                 TYPE      MEMORY_REQ
          HWIC Slot 0      0x00200000
               PVDM 0      0x00200000
    Onboard devices &
         buffer pools      0x0228F000
               TOTAL:      0x0268F000
Rounded IOMEM up to: 40Mb.
Using 7 percent iomem. [40Mb/512Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(1)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 22-Mar-10 02:13 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2901/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FGL162722DK
2 Gigabit Ethernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
Press RETURN to get started!
*Mar  1 00:00:04.931: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2900 Next reboot level = ipbasek9 and License = ipbasek9
*Mar  1 00:00:05.019: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2900 Next reboot level = uck9 and License = uck9
*Jan 23 07:37:07.403: %IFMGR-7-NO_IFINDEX_FILE: Unable to open nvram:/ifIndex-table No such file or directory
*Jan 23 07:37:15.119: %MAINBOARD-1-UNKNOWN_WIC: wic card in location 0/0 has an unknown id 0x6EF
*Jan 23 07:37:18.679: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jan 23 07:37:18.679: %LINK-5-CHANGED: Interface GigabitEthernet0/0, changed state to reset
*Jan 23 07:37:18.679: %LINK-5-CHANGED: Interface GigabitEthernet0/1, changed state to reset
*Jan 23 07:37:19.887: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Jan 23 07:37:19.887: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Jan 23 07:37:20.823: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
*Jan 23 07:37:20.823: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
*Jan 23 07:37:21.063: %SYS-5-CONFIG_I: Configured from memory by console
*Jan 23 07:37:23.083: %LINK-5-CHANGED: Interface GigabitEthernet0/1, changed state to administratively down
*Jan 23 07:37:23.755: %SYS-5-RESTART: System restarted --
*Jan 23 07:37:23.759: %SNMP-5-COLDSTART: SNMP agent on host Hewitt_Noida is undergoing a cold start
*Jan 23 07:37:37.483: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
*Jan 23 07:37:37.483: %DSPRM-5-UPDOWN: DSP 3 in slot 0, changed state to up
*Jan 23 07:37:37.483: %DSPRM-5-UPDOWN: DSP 2 in slot 0, changed state to up
Hewitt_Noida>
Hewitt_Noida>
Hewitt_Noida>
Hewitt_Noida>en
Hewitt_Noida#
Hewitt_Noida#
Hewitt_Noida#sh diag
Slot 0:
        C2901 Mother board 2GE, integrated VPN and 4W Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time 00:00:56 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC1624697D
        Hardware Revision        : 1.0
        Part Number              : 73-11834-08
        Top Assy. Part Number    : 800-30795-06
        Board Revision           : A0
        Deviation Number         : 123694
        Fab Version              : 03
        Product (FRU) Number     : CISCO2901/K9
        Version Identifier       : V06
        CLEI Code                : CMMJA00ARA
        Processor type           : C1
        Chassis Serial Number    : FGL162722DK
        Chassis MAC Address      : d48c.b51a.b668
        MAC Address block size   : 72
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 36 32 34 36 39 37 44 40
          0x10: 06 17 41 01 00 82 49 2E 3A 08 C0 46 03 20 00 78
          0x20: 4B 06 42 41 30 88 00 01 E3 2E 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 30 31 2F 4B 39 89 56 30 36 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 4A 41 30 30 41 52
          0x50: 41 09 C1 C2 8B 46 47 4C 31 36 32 37 32 32 44 4B
          0x60: C3 06 D4 8C B5 1A B6 68 43 00 48 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 65 40 01 25 41 00 87 42 00
          0x80: 00 F8 00 28 03 E8 1C 89 07 D0 20 21 0B B8 20 93
          0x90: 0F A0 21 2F 13 88 21 83 17 70 21 A8 1B 58 21 B0
          0xA0: 1F 40 21 AB 23 28 21 79 27 10 21 78 41 01 1D 42
          0xB0: 00 00 F8 00 28 03 E8 1C 20 07 D0 1F 40 0B B8 20
          0xC0: 6C 0F A0 21 34 13 88 21 34 17 70 21 98 1B 58 21
          0xD0: 98 1F 40 21 98 23 28 21 34 27 10 21 34 FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 0:
        128-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11810-03
        Board Revision           : C0
        Deviation Number         : 0
        Fab Version              : 03
        PCB Serial Number        : FOC1602145Q
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-128
        Version Identifier       : V01
          0x00: 04 FF 40 05 DC 41 01 00 82 49 2E 22 03 42 43 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 36 30 32
          0x20: 31 34 35 51 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 31 32 38 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        Unknown WAN daughter card
        Top Assy. Part Number    : 800-34658-01
        Part Number              : 73-13420-01
        Board Revision           : B0
        Deviation Number         : 124402
        Fab Version              : 05
        PCB Serial Number        : FOC16100L9C
        Product (FRU) Number     : VWIC3-2MFT-T1/E1
        CLEI Code                : COUIA7NCAA
        RMA History              : 00
          0x00: 04 FF 40 06 EF 41 01 00 C0 46 03 20 00 87 62 01
          0x10: 82 49 34 6C 01 42 42 30 88 00 01 E5 F2 02 05 C1
          0x20: 8B 46 4F 43 31 36 31 30 30 4C 39 43 89 56 30 31
          0x30: 20 CB 90 56 57 49 43 33 2D 32 4D 46 54 2D 54 31
          0x40: 2F 45 31 C6 8A 43 4F 55 49 41 37 4E 43 41 41 03
          0x50: 00 81 00 00 00 00 04 00 D9 03 40 C1 CB FF FF FF
Hewitt_Noida#
1 ACCEPTED SOLUTION
Hi Akshay,
As per
http://www.cisco.com/en/US/partner/prod/collateral/routers/ps5855/data_sheet_c36-609138.html
VWIC3-1MFT-T1/E1 is supported since 15.1(1)T1 and later.
Make sure you have this minimum IOS.
Manish
VIP Purple
Hi Akshay,
Can u share the show running and sh license all from router?
Did u configure card type e1 command ?
regds,
aman
Hi Akshay,
As per
Manish
Thanks all.
I have upgrade the IOS and now all commands running.
Akshay.
1925
