Community Member
VWIC2-1MFT-T1/E1 and ITU-T G.703
Can you tell me if  VWIC2-1MFT-T1/E1 is compatible with standard ITU-T G.703?
I've got router 2821 with PVDM2-32
1 ACCEPTED SOLUTION
Silver
Re: VWIC2-1MFT-T1/E1 and ITU-T G.703
I suppose your VWIC2-1MFT-T1/E1 card is intended to be used in your 2800 voice gateway for external pstn calls. You can ask to your provider to get an E1-PRI (if in Europe) access for your voice calls. Also in function of your call volume, you can even ask to get only E1 partial channels activated  (for example 15 instead of the 30 voice channels).
Best regards
Karim
Silver
Hello Bagnolini;
According to table-2 of this link, NO :http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d2db.html
You have to get VWIC2-1MFT-G703 (or VWIC2-2MFT-G703) module which supports G.703 (unstructured E1).
Regards.
Karim
Community Member
Ok, what standard I have to ask to my provider?
Silver
Best regards
Karim
Community Member
Can you give me a simple example for configure this kind of card?
734
