03-10-2009 08:49 AM - edited 03-15-2019 04:44 PM
Guys,
I have a customer who has reported aproblem with VWIC2-2MFT-G703 and MGCP. The card is not registering with CCM. I will be visiting the customer tomorrow.
I just want to know if the mgcp configs for this card is the same as VWIC2-2MFT-T1/E1 cards?
Does anyone have a sample config for this card for UK?
Solved! Go to Solution.
03-10-2009 11:06 AM
The G703 variant is only relevant for data, so this should not play a factor.
You should be able to configure this like any other MGCP gateway.
Make sure that the output of 'show mgcp | i MGCP Domain Name' matches the name you've given it in CUCM
hth,
nick
03-10-2009 11:06 AM
hth,
nick
03-10-2009 11:51 AM
Thanks Nic.
