VWIC2-2MFT-T1/E1 - All channels stop working
All,
We are configuring an environment with 7 E1 cards model VWIC2-2MFT-T1/E1 totalizing 14 E1´s interfaces.
We have 7 Interfaces in a trunk group for PABX and 7 ones in a trunk group for PSTN.
When enabling two or more cards, when one of the cables either from PABX or PSTN are desconected (simulating a failure), all channels stop working.
After a period of 5-10 minutes with the cable removed, the channels of the remained cables start to work properly again.
Questions:
1-) Is it possible to reduce the period that the gateway notice that the cable is removed and stop trying to use it?
2-) Is it possible to modify the order that the channels are occuped?
Configuration:
card type e1 0 0
card type e1 0 1
network-clock-participate wic 0
network-clock-participate wic 1
controller E1 0/0/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
country brazil
metering
double-answer
answer-signal group-b 1
trunk-group PSTN
description ### CONEXAO COM PSTN ###
controller E1 0/0/1
framing NO-CRC4
clock source internal
cas-custom 0
country brazil
metering
double-answer
trunk-group PABX
description ### CONEXAO COM PABX ###
controller E1 0/1/0
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
country brazil
metering
double-answer
trunk-group PSTN
controller E1 0/1/1
framing NO-CRC4
cas-custom 1
country brazil
metering
double-answer
trunk-group PABX
voice-port 0/0/0:0
translation-profile incoming IncomingPSTN
cptone BR
timeouts call-disconnect 1
voice-port 0/1/0:1
cptone BR
voice-port 0/0/1:0
translation-profile incoming IncomingPABX
cptone BR
voice-port 0/1/1:1
cptone BR
dial-peer voice 1 pots
description PSTN
incoming called-number .
direct-inward-dial
forward-digits all
dial-peer voice 2 voip
incoming called-number .+
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
ip qos dscp cs3 media
dial-peer voice 11 voip
description ### DIAL-PEER VOIP PARA CUCM 1 ###
preference 1
destination-pattern .T
session target ipv4:192.168.4.13
voice-class codec 1
voice-class h323 1
dial-peer voice 12 voip
description ### DIAL-PEER VOIP PARA CUCM 2 ###
preference 2
session target ipv4:192.168.4.14
voice-class codec 1
voice-class h323 1
dial-peer voice 13 voip
description ### DIAL-PEER VOIP PARA CUCM 3 ###
preference 3
session target ipv4:192.168.4.15
voice-class codec 1
voice-class h323 1
dial-peer voice 14 voip
description ### DIAL-PEER VOIP PARA CUCM 4 ###
preference 4
session target ipv4:192.168.4.16
voice-class codec 1
voice-class h323 1
dial-peer voice 15 voip
description ### DIAL-PEER VOIP PARA CUCM 5 ###
preference 5
session target ipv4:192.168.8.11
voice-class codec 1
voice-class h323 1
dial-peer voice 16 voip
description ### DIAL-PEER VOIP PARA CUCM 6 ###
preference 6
session target ipv4:192.168.8.12
voice-class codec 1
voice-class h323 1
dial-peer voice 17 voip
description ### DIAL-PEER VOIP PARA CUCM 7 ###
preference 7
session target ipv4:192.168.8.13
voice-class codec 1
voice-class h323 1
dial-peer voice 18 voip
description ### DIAL-PEER VOIP PARA CUCM 8 ###
preference 8
session target ipv4:192.168.8.14
voice-class codec 1
voice-class h323 1
dial-peer voice 20 pots
trunkgroup PSTN
description ### DIAL-PEER POTS REDUNDANCIA PSTN ###
preference 9
dial-peer voice 111 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA EXCLUSIVA FAX ###
destination-pattern 1111[2-5].......
fax rate disable
dial-peer voice 112 pots
trunkgroup PSTN
destination-pattern 1111..T
fax rate disable
prefix 031
dial-peer voice 1001 pots
trunkgroup PABX
description ### DIAL-PEER POTS CHAMADA ENTRADA PABX ###
destination-pattern 613105[5-7]...
forward-digits 4
dial-peer voice 101 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA LOCAL FIXO ###
destination-pattern [2-5].......
dial-peer voice 102 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA LOCAL CELULAR ###
destination-pattern [6-9].......
dial-peer voice 103 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA DDD FIXO ###
destination-pattern 0[1-9]...[2-5].......
prefix 0
dial-peer voice 104 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA DDD CELULAR ###
destination-pattern 0[1-9]...[6-9].......
prefix 0
dial-peer voice 105 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA DDI ###
destination-pattern 00T
prefix 00
dial-peer voice 106 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA 0500 ###
destination-pattern 0500T
prefix 0500
dial-peer voice 107 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA 0300 ###
destination-pattern 0300T
prefix 0300
dial-peer voice 108 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA 0800 ###
destination-pattern 0800T
prefix 0800
dial-peer voice 109 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA SERVICOS ###
destination-pattern 103T
prefix 103
dial-peer voice 110 pots
trunkgroup PSTN
destination-pattern 1T
prefix 1
Luciane de Medeiros
1 REPLY
All,
It was solved with the commands below.
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
Thanks!
Luciane de Medeiros
335
