VWIC2-2MFT-T1/E1 ISDN Problem
Hi Experts,
I have a 2911 router runing CME with 2 VWIC2-2MFT-T1/E1 , 2 ports of 1 card are going to be used for data circuits while 2 ports of other card are going to be used for voice T1.
I am able to configure data ports successfully but when I try to configure voice interfares I am having trouble.
1. I don't see a Serial0/1/0:23 interface . Instead I see it as Serial0/1/0:0
2. It does not accept any ISDN comand.
Following is show inventory and controller configuration.
col-CME#sh inventory
NAME: "CISCO2921/K9 chassis", DESCR: "CISCO2921/K9 chassis"
PID: CISCO2921/K9      , VID: V01 , SN: FTX1420AHUR
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1  , VID: V01 , SN: FOC141741H5
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 1", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1  , VID: V01 , SN: FOC141741RZ
NAME: "2nd generation two port FXO voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation two port FXO voice interface daughtercard"
PID: VIC2-2FXO         , VID: V02 , SN: FOC14154MC7
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32          , VID: V01 , SN: FOC141504WM
NAME: "Internal Services Module with Services Ready Engine on Slot 0", DESCR: "Internal Services Module with Services Ready Engine"
PID: ISM-SRE-300-K9    , VID: V01 , SN: FOC14120C5B
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC    , VID: V01 , SN: QCS1415H0MY
card type t1 0 0
card type t1 0 1
controller T1 0/0/0
cablelength long 0db
channel-group 0 timeslots 1-24
controller T1 0/0/1
controller T1 0/1/0
controller T1 0/1/1
interface Serial0/0/0:0
description MLPPP link to ATT MPLS
no ip address
encapsulation ppp
ppp multilink
ppp multilink group 1
max-reserved-bandwidth 95
interface Serial0/0/1:0
no ip address
encapsulation ppp
ppp multilink
interface Serial0/1/0:0
description reserved for PRI
no ip address
interface Serial0/1/1:0
no ip address
Please have a look and tell me if im missing something.
Everyone's tags (4)
VIP Super Bronze
Re: VWIC2-2MFT-T1/E1 ISDN Problem
You need the comand..pri-group timeslots 1-24 under te controller you want to use for voice. Once that is configured your "D channel" will b available.
controller T1 0/1/0
this will autoimatically create..interface s0/1/0:23.
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Also don't forget to issue the commands before applying pri-group under controllers:
     isdn switch-type xxxx
     network-clock-participate wic xxxx
2472
