Community Member
vwic3-1mft-t1/e1 cd/lp p0
do you know if this module can be used for voice?
thanks
Lorenzo
------- have a look to my blog lgrconsulting.com
Everyone's tags (3)
Blue
You can use vwic3-1mft-t1/e1 for voice provided you have PVDM modules inserted in router.
Ronak Patel
Please rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Community Member
Thanks for your quick reply.
I wasn't sure because on the old vwic2 there was written ctrl t1/e1 and not cd/lp p0.
thanks
Blue
In cards terminology CD and LP is following.
• CD (data carrier detect): Indicates a received error on the telco link
• LP (loopback): Indicates that the interface is in loopback mode
Do you have "vwic3-1mft-t1/e1 cd/lp p0" as part number?
Ronak Patel
rate helpful posts.
786
