VWIC3-2MFT-T1/E1 Question
I think this card can be programmed for either a data T1 or a PRI but can someone confirm that on the 2 port card 1 port can be configured as a PRI port and the other can be configured for a data T1?
Thanks in advance!       Replies rated.
1 ACCEPTED SOLUTION
Silver
Yes the VWIC should be able to handle both duties.  It all hinges on the configuration of the port within your running config.
Tony
Please rate helpful posts!
Tony
1 REPLY
Silver
Tony
Tony
103
