VWIC3-4MFT-T1/E1 not available in CUCM
Hi All,
I'm not able to find VWIC3-4MFT-T1/E1 option in my call manager while configuring MGCP gateway.
Router Model : Cisco 2951
CUCM Version : 7.1.3.32900-4.
Kindly suggest me a solution.
Loga S
CCNP R&S,CCNA Voice.
hi Loganathan,
Minimum Cisco Unified Communications Manager Release required for VWIC3-4MFT-T1/E1 is  7.1.5 or 8.0.2
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd8057f2e0.pdf
Hope this helps!
Karthik
Hi Karthik,
You mean to say like,i have to upgrade my Call Manager version.Right??
If so does it require a system restart???
Loga S
it requires CUCM version 7.1.5 or 8.X. please find the below link for reference
Baskaran.M
Hall of Fame Super Gold
Use H.323 os SIP instead of MGCP.
Beside being indipendant from the hardware used, you will enjoy better stability, easier configuration, and a much richer set of features with no protocol-derived limitations.
I'm having exactly the same issue with a 3945, but do have version 7.1.5.2000.6 - which should support this VWIC.
Blue
Upgrade to latest CUCM 7.1.5 release, it wil resolve the issue.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtg31562
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
1474
