Community Member
VXML Compliant Voice Gateways
Does ISR Routers support VXML compliant Voice Gateways Solutions for IVR applications?
1 REPLY
Re: VXML Compliant Voice Gateways
Both the 28xx & 38xx series ISR routers support VXML compliant solutions for IVR applications. VXML is supported on IP Voice with minimum IOS release of 12.4(6)XT.
Please refer to the following link for additional details.
http://www.cisco.com/application/pdf/en/us/guest/products/ps1006/c1225/ccmigration_09186a00807c624b.pdf
259
