VXML dude
I developed a VXMl application few months ago and it works well, but now it doesn?t work fine (I don?t know if the IOS version in the router has been change or if there was a change on a dial-peer (I think not).
the problem is that now in a dtmf field, it store the called number also the digits pressed.
any ideas??
this is the vxml code :
<field name="DATA" type="digits?minlength=3;maxlength=8">
<grammar type="application/grammar+regex">[1234567890]+</grammar>
<filled>
<submit next="<?php echo($path);?>DATA.php" method="post" namelist=" DATA"/> </filled>
any ideas
It think is anything in the IOS config.
thanks in advance
  • IP Telephony
1 REPLY
 Can you post your XML output
Can you post your XML output after your PHP processing?
159
