07-22-2009 03:20 AM - edited 03-15-2019 07:03 PM
hi,
i'm installing a brand new CUCM 7.0 at a brand new HP server. all is fine, the tests of media going fine, and installation goes on until a screen appears: application post install. Database Installation.
The estimated time of this process exceeded and the system extended the time to 2 hours and 40 minutes. So i see now the picture (attachment) and i believe there's nothing happen anymore. Should I wait the whole extended time? I've tried to restart and reinstall the cucm, without change.
please look at attachment.
07-22-2009 03:36 AM
Make sure your DNS has all the proper entries, it might take up to 4 hours to complete.
If your DNS is not properly populated stop the install, populate DNS and redo the install. It might still take a long time so you'll have to wait.
java
if this helps, please rate
07-22-2009 05:13 AM
why dns? there were a dialog before the process (see attachment). the system ask for dns, because it was not found dns-server. this is alright, because i set the dns- ip-adresses, but the server are not available. the dns-server are located at the customer site but the cucm i install here at the office.
02-26-2010 01:52 AM
I have the same "problem"..
Tha installation lasts over a day!
But I don't really know if this is indeed a problem.
Since the installation completes I make the config at the server, the phones are registered and it seems to work fine.
I cannot understand why it takes sooo much time to be completed.
