05-17-2012 02:45 PM - edited 03-16-2019 11:13 AM
All,
does anyone know of a way to let a user set a call to be made to a specific DN at a specific time without using a 3rd party tool? Scenario is putting CallManager in service at a hotel but the front desk needs to be able to set wake up calls for the guests. so far the 3rd party hospitality add-on programs I have seen are fairly costly and this is a smaller hotel that can't take the hit.
Thanks in advance and all replies are rated
05-17-2012 05:03 PM
You can not do that natively, you will need to look into 3rd party options.
05-17-2012 05:32 PM
Not 100% sure, but I think Paolo has something similar, you might want to reach him.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-17-2012 06:27 PM
Thanks Chris and Javalenc,
I dropped Paolo a note to check. Wondering how hard it would be to get an IP Phone Service that does this developed from the ground up. Any ideas?
