Community Member
wake up calls
how I can configured wake up calls at cm 5.1
Re: wake up calls
You can't CUCM is a call agent, not an IVR.
You need UCCX/UCCE and develop the script to achieve this.
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hall of Fame Super Gold
Re: wake up calls
If you use H.323, you can use the alarm TCL/IVR script that I wrote:
www.ciscoscripts.com
Community Member
Re: wake up calls
Please
have a guide that can help me
thanks
Re: wake up calls
It's in the script, read it.
Community Member
wake up calls
Hi Paolo,
The link seems to take me to a site where you have to buy the scritps - no longer free - is there any way I can get the wake up call script directly from you?
Thanks!
Re: wake up calls
The scripts are directly from me, and they aren't free.
408
