Walkie Talkie effect when using speakerphone 6961
Hi all,
I am experiencing some voice quality problems when using the cisco 6961 speakerphone .
The quality is fine when we use handset, but when i switch to speakerphone i can't hear the other side till i stop talking , like a walkie -talkie.
I am using CUCM 8.5 , i did a phone upgrade from 9.0.3 to the latest 9.2.2.6 without success.
Any help will be much appreciated.
Kind regards
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Youssef,
This bug sounds quite similar and although it only mentions the 6921 I'm pretty sure is
what you are seeing/hearing;
CSCtu09371            Bug Details
When Speaker is enabled, low audio observed when both the parties speak
Symptom:
Customer is experiencing intermittent audio issues with 6921 phone when Speaker on the phone is enabled. During the conversation, few words sound very low audio level. Everything works fine if they use the phone handset or use a different phone model.
Conditions:
Issue exists with all the calls made using the speaker button of the 6921 phone and appears for both internal and external calls.
Workaround:
NA
StatusStatus
Open
Severity Severity
3 - moderate
Last Modified Last Modified
In Last Year
Product Product
Cisco Unified IP Phone 6900 Series
Technology Technology
1st Found-In 1st Found-in
9.2(1)
Cheers!
Rob
Hi Youssef,
We are facing the same problem with one of our customer using this type of IP Phones. If you found a solution for this problem, please share.
Regards.
Hi Youssef,
Symptom:
Conditions:
Workaround:
NA
StatusStatus
Open
Severity Severity
3 - moderate
In Last Year
Product Product
9.2(1)
Cheers!
Rob
Hi Rob,
Thanks a lot for your answer.
We have the confirmation from Cisco TAC saying that the CSCtu09371  Bug is causing this malfunction.
Here is the TAC answer:
. I have confirmed bug CSCtu09371 should be fixed in firmware 9.3(1) which will be released at the end of May 2012.
Unfortunately, there is no workaround for this issue. In the meantime, maybe the users should avoid using the speakerphone feature.
555
