Wallmount kit for CP-7931
Hi, Can we use both CP-LCKNGWALLMOUNT(Flat) and CP-LCKNGWALLMNT2(Slanted) with CP-7931?
or, CP-7931 can use with only CP-LCKNGWALLMNT2(Slanted)?
When I see the datasheet of CP-7931,
only CP-LCKNGWALLMNT2(Slanted) is on the sheet.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps7062/product_data_sheet0900aecd80534259.html
Your advice will be appreicated.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Wallmount kit for CP-7931
Hi Katsukiyo,
The problem with the "older" (CP-LCKNGWALLMOUNT) Wall Mount kit is that it uses the Pin holes from the articulating style "footstand" to mount the phone, which is not avalable on the IP Phone models like the 7931,7911,7912 and 7905 (see step b & c below)
b. On the back of the phone's footstand, push out the pins and remove the stand. You might need to use a screwdriver or other pointed device to push out the pins. The pins are firmly set, so it requires significant force to push them out.
c. Attach the bracket by inserting the pins in the same holes vacated by the footstand. The phone's ports should be accessible through the holes in the bracket
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/all_models/wallmount/english/install/guide/ippmount.html
So you must use;
CP-LCKNGWALLMNT2=
Universal locking wall-mounting kit
7905,7911,7912
CP-LCKNGWALLMNT2=
From this guide;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_data_sheet0900aecd8039de52.html
Hope this helps!
Rob
1 REPLY
Hi Katsukiyo,
So you must use;
CP-LCKNGWALLMNT2=
7905,7911,7912
CP-LCKNGWALLMNT2=
From this guide;
Hope this helps!
Rob
929
