wan link call control
Can anyone tell me how I can control the number of calls going across a wan link. I am aware you can use locations in CCM. This scenario however is different. 1 site is ccm and the other is a PBX. They are connected via 2 routers using QSIG. I was hoping there was something you can do on the routers
1 ACCEPTED SOLUTION
Re: wan link call control
simply on the outgoing dial peer add the foolowing cammnad
dial-peer voice 9 voip
max-conn [max number of calls]
for wxample if u want to limit the number of calls to 9
do the following on the outbound voip dialpeer going to the other one
dial-peer voice 1 voip
max-conn 9
! 9 calls allowed on VoIP Dial Peer to Remote Site
good luck
if helpful Rate
1 REPLY
max-conn 9
good luck
if helpful Rate
125
