Want Call Waiting indication only for external call on CME
Hello
I have a CME 7.1.
My ephone-dn are configured in dual line mode in order to have call-waiting.
My quesiton is: when the DN is busy is there a way to have call-waiting indicator for External call and the busy signal for internal call (specific config with other line type ect...).
Thanks for your help.
Best regards
Hall of Fame Super Red
Re: Want Call Waiting indication only for external call on CME
Hi Florence,
Have you tried;
forward local-calls
To allow internal (local) calls to be forwarded, use the forward local-calls command in ephone-dn or ephone-hunt configuration mode. To prevent internal calls from being forwarded, use the no form of this command.
forward local-calls
no forward local-calls
Syntax Description
This command has no arguments or keywords.
Command Default
Internal calls are forwarded as specified in the ephone-dn or ephone-hunt configuration of the called party.
Usage Guidelines
Internal, or local, calls are defined as those calls that originate from other ephone-dns in the same Cisco Unified CME system.
When the no forward local-calls command is used in ephone-dn configuration mode, internal calls to that ephone-dn are not forwarded if the ephone-dn is busy or does not answer. If the ephone-dn is busy, the caller hears a busy signal. If the ephone-dn does not answer, the caller hears a ringback signal. The call is not forwarded even if call forwarding is enabled for the ephone-dn.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_f1ht.html#wp1023323
Hope this helps!
Rob
Hi Rob
thanks for your answer.
I tried the no forward local call on the dn but that do not applied in case of call waiting.
Even if the option is configured it still ringing on dn for local call when call waiting is enable.
best regards
Florence
Hall of Fame Super Gold
If you're positive you have configured correctly, but doesn't work as described, please contact the TAC.
This appears to be a little-know feature so a bug may have slipped in.
148
