Want to add Mobile Phone and IP Phone Number in LDAP Integration
Hi guys
I have integrated my CUCM 8.5 with MS AD. There is no problem in Integration.
But I want to add one more features.
Right now  I am having only one number which is IpPhone in Corporate directory field. All of my corporate usres are having IPPhone as well as Mobile Phone. I want to show both entries under user name at corporate directory.
In AD user propertise there is a Tab telephones. Mobile / FAX/ IP Phone numbers are there.
How Could I show IP Phone and MobilePhone Number in my Corporate directory?
  • IP Telephony
The Corporate Directory application built into CUCM is just a web application that serves up XML to the IP phones. You can create a custom coprorate directory that presents more information to the IP phone. You will need to some coding or hire someone who can.
Info:
http://developer.cisco.com/web/ipps/docs
I have written a couple of these for my customers. It is pretty straightforward. Of course, I haven't used the SDK example in a while and I am not sure if they moved beyond the older ASP framework yet. They may have a JSP version too.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Hi William
At last I am able to build custom asp script for this. This custom application can search IP Phone , Cell Phone. If anyone need more field I can add.
Now I am thinking that its pretty simple . I am using asp version.
Sultan Al Arif
442
