Community Member
Wanting not to show calling name/number on CUCM
My CEO asked me to mask his name and number when calling to internal DN, I've been checking on the manual, but I couldn't find nothing like this. I'm able to hide or change the name, but the DN always appears in the bottom of the name between parenthesis.
Does any body knows if this is possible?
Please I'll be really grateful with this information..!!
Fernando Vazquez
Everyone's tags (2)
1 REPLY
Re: Wanting not to show calling name/number on CUCM
Depending on your version you can use either calling party transformation patterns or translation patterns to achieve that.
EDIT: there are plenty of threads on the matter, just search for hide number or something similar to get more info and examples.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
162
