Community Member
Warning RTMT
we experiencing a problem in RTMT syslog messages, there are a lot of these message :
WARNING : /etc/modprobe.conf line 9: ignoring bad line starting with 'if'
WARNING : /etc/modprobe.conf line 11: ignoring bad line starting with 'endif'
I have'nt any problem on the CUCM, but the syslog is full of this messages and i can see any other alarm.
Version 7.0.2.20000-5
Thank you in advance.
Fabrizio
1 ACCEPTED SOLUTION
Blue
Warning RTMT
HI
It is cosmetic issue.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsv01620
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
Warning RTMT
HI
Ronak Patel
Rate helpful posts.
Community Member
Warning RTMT
thank you for your answer.
I wil update the version.
Fabrizio
376
