Way to remove Pending Voicemails from CUCM
Dear All,
Is there any way to remove the End User's Voicemails of His/Her Directory number from the Call Manager
In Detail: If the user is having a Voicemail and he/she is unabel to remove that voicemail, Instead of remove the voicemail box/profile, Only i want to clear that message/messages from his profile.
Kindly helpe me, How to do, Thanks!!!
Bala
1 REPLY
Dear Bala,
1) I assume that you are talking about the MWI (Message Waiting Indicator) light (or message icon) on the end user's phone device. And i believe for some reason this light is continously blinking. If this is the issue, then following is the resolution,
Resolution: Dial the 'MWI OFF' number from the user's phone. Following is the path to locate it,
CUCM --> Feature > Voice Mail > Message Waiting
2) If you are referring to actually deleting the voicemail messages from the user's voicemail box, then there should be a Unity server or Unity Express. You will have to login into this device.
For Unity Server:
UNity Server --> Subscribers --> search by extn
Access the voicemail box --> Empty or Delete the voicemail messages
For Unity Express
Unity Express --> Users --> search by extn
Hope this helps.
achilleus
509
