Web acces of IP phone
Hi Team,
I am getting following error when i am trying to  web acces of IP phone also due to this i am not able to find serial number of this device, please help me
HTTP Error 403.14 - Forbidden
The Web server is configured to not list the contents of this directory.
HTTP Status 404 - /ccmadmin/reports/devicelistx.asp
Prafull S.
On the physicall phone I assume you have call manager and not express is web access enabled ?
Voice CCIE #37771
Yes, correct Cisco UCM 9.0
Praful S
Also Please note that we have recently install this CUCM. 9.0
Prafull S
is the following enabled on the phone it self?
Voice CCIE #37771
Yes,
Already Enabled. Is anything setting need to done @ Service/enterpise parameter for activating web acces of IP phone?
Prafull S
nope if everything was setup to system defaults and you have eanbled web access on the phone and you have access to that IP range from your machine which you try to access it all should be fine.
Can you ping the IP of the phone?
Voice CCIE #37771
129
