Community Member
Web Directory for CUCM 6.0
Hello Everyone,
I just finished my first install of CUCM 6.0, and I have a question from my customer.
They have a company intranet site, and a web developer who updates that site. He is interested in knowing if there is a way to dip into the CUCM user database and grab information on users and extensions.
He would then use this information to populate a web directory for his intranet page. I've seen this done in an earlier version of CCM with Windows and SQL, but I don't
know if this is possible in the Linux/Informix format. His need is to be able to grab the data from CUCM so he doesn't need to populate this data twice.
Any information would be appreciated.
Community Member
Re: Web Directory for CUCM 6.0
Hi I don't have any answers to your question, but rather I have some questions for you. Did you install CUCM 6 from scratch? Can you outline the steps you took? Once you completed did you run into any problems? I'm looking to upgrade from 4.0(2a) onto 2 different serverss in a cluster. Any advice would be appreciated
Silver
As far as I know, this is not possible.
Community Member
Hi William,
You may want to look at the Webdialer part of CUCM/CCM, maybe to intgrate it in their existing Intranet. Besides the availability of names and their numbers you will get the possibility to "click-and-dial"!
149
