Web Directory for UCM 6.x
Is there a direct web link to the Corporate Directory from UCM 6.x that DOESN'T require a login? The one we used for 4.x was something like http://<cm ip>/ccmuser/directory.asp
Thanks in advance.
Re: Web Directory for UCM 6.x
the corporate directory doesn't ask PWD in any version.
in 6.X you need it for PAB and SD but not for corporate directory
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks ... but can you tell me the direct link to the directory? The one I pointed out in my previous post doesn't work.
it's in various several posts before so please try searching NetPro
http://IP:8080/ccmcip/xmldirectory.jsp
java
java
Thanks ... tried your link (with our CM's IP) but receive an error:
XML Parsing Error: XML or text declaration not at start of entity
Line Number 2, Column 1:
Hey Java,
I tried that on my version of 6.x and it doesnt work..I get the following:
HTTP Status 404 - /ccmip/xmldirectory.jsp
type Status report
message /ccmip/xmldirectory.jsp
description The requested resource (/ccmip/xmldirectory.jsp) is not available.
Apache Tomcat/5.5.17
Please disregard above post.
i assume you configured this under URL directories and are not trying to access this thru a browser right?????
java
java
Sorry, no ... my original question was about the direct web link, for a web browser.
Perhaps you're confused ... I'm referring to accessing the Corporate Directory from a web browser, not the IP Phone. In Callmanager 4.x, the link was "http://x.x.x.x/ccmuser/directory.asp". I'm looking for the equivalent in Communications Manager 6.x.
Brian
I also am looking for this facility. One way would be to setup a generic user for the login, but it would be preferable to be able to get direct web access.
556
