Webdialer and NAT
We have a voice network that is completely separate of the data network (due to some security restrictions). Both networks are connected to the internet. We have a CUCM v6.1.3a.
I wonder if it is possible to use Webdialer/Click2Call widget on desktops in the data network. The voice network has a firewall that can do Network Address Translation.
Is Webdialer through NAT possible, and if so, which port(s) do we have to open?
Tim
Green
Re: Webdialer and NAT
why you need to do NAT between data and voice?
I will use VPN
NAT may have some issues with CTI
The telephony network is completely separated from the office (data) network due to historical reasons. The telephony network has a low-cost firewall that allows NAT/PAT, and that is the only way we can have webdialer requests coming in from PCs in the office network. VPN is not possible between the two networks.
Anyhow, I expected some issues with NAT so it was worth a try.
NAT will definitely cause issues with this setup. If security is an issue, then why not use CTL files to encrypt phone traffic and use IPSEC to the gateway. Just a thought to get around your issue so that you can get the features you are looking for...
134
