WebEx Solution in BE6K
Is it Possible BE6K UCS220 M3 server support  WebEx,currently PUB,UC,IM running on the server is there possible i can add onemore?
I have seen in doccument mentioned below
Cisco Business Edition 6000 integrates with cloud based webex Software-as-a-service offerings including Webex connect IM and presence as well as webex web conferencing
Is this Webex Meeting Center come with ova file loaded on UCS? or just a webex cloud?
1 ACCEPTED SOLUTION
Re: WebEx Solution in BE6K
Hi Mate,
Webex cloud is a different product and as name implies is a cloud based product so you dont need any ova or any hardware. You just need to buy the service.
Webex on premise or CWMS on the other hand is a completely different product. You can not install it on a BE6K. Reason: it does not support co-residency with other UC apps:
Reference: http://www.cisco.com/c/en/us/td/docs/collaboration/CWMS/1_5/System_Requirements/System_Requirements_chapter_00.html#reference_BA7FE746303149E69A845B5D09C44D9A
Scroll to Hypervisor section
Co-residency with Cisco Unified Communications products on the same physical ESXi host is not supported.
Can anybody help me on this scenario
Hi Mate,
287
