WebEx
Siva chinap
Level 5
Level 5
Is it possible to add the WebEx service in the Excising blade server? If no what are the additional hardware /Software /Licence required can anybody suggest me
Terry Cheema
I beleive you are referring to WebEx on premises - CWMS server.
1) CWMS is supported only on the UCS server. Refer below link for the hardware requirements, chose according to your system size:
http://www.cisco.com/en/US/docs/collaboration/CWMS/b_System_Requirements_chapter_00.html#reference_EE2655849348437FB3A34F4C4D3E1F71
2) Another requirements: You will need Vcenter license (if you dont have Vcenter already)
VMware license
User licenses depending upon your needs.
Refer to General system requirements:
http://www.cisco.com/en/US/docs/collaboration/CWMS/b_System_Requirements_chapter_00.html#reference_BA7FE746303149E69A845B5D09C44D9A
-Terry
It could be posible but will bw not supported by Cisco. The requirement are:
Platform Requirements
• VMware v5.0 or v5.1
• Cisco UCS servers: for smaller (50 and 250 user) systems: Cisco UCS C220 M3 or above; for larger (800 and 2,000 user) systems: Cisco UCS C460 M2 or above
• CUCM v 7.1, 8.6, 9.0 or 9.1 (for SIP trunk audio conferencing)
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Terry Cheema
VMware license
-Terry
Hi Terry,
Thanks for your valuable information,
No probs mate - if you don't have any other query please mark the thread as answered.
-Terry
