Bronze
Weird Codec Problem at CCM 4.23
It happens suddenly today.
We have CCM cluster 4.23, all the MGCP PRI located at main site, all the remote site make and receive call through main site.
CCM Region is set up as G729 between offices to save bandwidth.
Today, remote office could not receive and make call.
Phone will ring, but it will go fast busy after pick up.
Then I change all the Region to change G711, then everything is fine.
I mean it has been working for years, and suddenly not working today.
Anyone happen before??
P.S. I only upgrade the the MGCP router (2821) to latest code, the router also configure as SCCP for transcoder and conference, then I reverse back to original IOS, but still doesnt work.
Thanks for help..
Re: Weird Codec Problem at CCM 4.23
Is it only outside (PSTN) calls can not be received & placed at the remote office or even the calls from Main site's Cisco IP Phone as well ?
Bronze
Only happen at remote site. Main site has no problem, because the region is G711.
The problem sounds like your XCODER is not working, i would recommend you to delete and recreate the XCODER profile on both GW and CUCM
java
if this helps, please rate
java
www.cisco.com/go/pdi
133
