Weird FXO problem
Hi guys,
Here is a weird thing.. I have a 2911 with : (C2900-UNIVERSALK9-M), Version 15.1(4)M4,  and 3 VIC2-4FXO cards.
From time to time a line will go into a weird state and I am not able to send calls through that port.. I do a shut, no shut, router reload and nothing happens... the only solution is to unplug the RJ-11 cable and life is good again...
I ran a test on the port that does not work:
test voice port 0/0/0 si-reg-read 29 1
OAK_VGW1#
Jul 30 22:25:13.145:
Values read from SiLabs Codec connected to DSP 0, channel 0:
Register 29 = 0xCE
A port that works:
OAK_VGW1#test voice port 0/0/1 si-reg-read 29 1
OAK_VGW1#
Jul 30 22:25:36.053:
Values read from SiLabs Codec connected to DSP 0, channel 1:
Register 29 = 0x34
The call will not busy out.. it will go through and you can see the port going off-hook but nothing happens:
A debug from a vpm signal does not tell me much:
ul 30 22:01:59.809: htsp_timer_stop3 htsp_setup_req
Jul 30 22:01:59.813: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Jul 30 22:01:59.813: [0/0/0] set signal state = 0xC timestamp = 0
Jul 30 22:01:59.813: dsp_set_sig_state: [0/0/0] packet_len=12 channel_id=128 packet_id=39 state=0xC timestamp=0x0
Jul 30 22:01:59.813: TGRM: reg_invoke_tgrm_call_update(0, 0, 0, 65535, 1, TGRM_CALL_BUSY, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
Jul 30 22:01:59.813: htsp_timer - 1300 msec
Jul 30 22:02:00.089: htsp_process_event: [0/0/0, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_0110]fxols_disc_clear
Jul 30 22:02:00.089: htsp_timer_stop2
OAK_VGW1(config-voiceport)#
Jul 30 22:02:00.089: htsp_timer - 1300 msec
Jul 30 22:02:01.389: htsp_process_event: [0/0/0, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER]fxols_wait_dial_timer  htsp_dial
Jul 30 22:02:01.389: mars_flex_dsprm_current_codec_comp:DSP:0 FLEX Complexity Codec
Jul 30 22:02:03.613: htsp_process_event: [0/0/0, FXOLS_WAIT_DIAL_DONE, E_DSP_DIALING_DONE]fxols_wait_dial_done htsp_progress
Jul 30 22:02:03.613: htsp_timer - 350 msec
Jul 30 22:02:03.613: htsp_call_bridged invoked
Jul 30 22:02:03.721: mars_flex_dsprm_current_codec_comp:DSP:0 FLEX Complexity Codec
Jul 30 22:02:03.721: flex_dsprm_forking_mixing_support:
Jul 30 22:02:03.721: htsp_process_event: [0/0/0, FXOLS_WAIT_CUT_THRU, E_HTSP_VOICE_CUT_THROUGH]fxols_handle_cut_thru
Jul 30 22:02:03.721: htsp_timer_stop
Port config is simple and it works fine except when the port goes down:
voice-port 0/0/0
trunk-group POTS 1
no battery-reversal
cable-detect
connection plar 8805
busyout forced
caller-id enable
voice-port 0/0/1
trunk-group POTS 1
caller-id enable
Port 0/0/0 is the one that does not work right now and I have it "busy out" so that the calls use other ports since the environment is in production.
I have tryied battery reversal, disconnect parameters... nothing!
The provider delivers the PSTN lines using and Adtran and they say that everything is good.
Any ideas?
Thanks!
Weird FXO problem
If you do a "show voice call summ", what is the status of the port?
If the port is an FXO, I don't think it's a problem with the port, however we have to proof it.
Have you tried moving the cables? Meaning, if the affected line is connected on port 0/0/0, move it for example to 0/0/1, and if the issue affects 0/0/1, it's definitively an issue with the line, otherwise an RMA will be needed, since there's not much you can do with an FXO
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Weird FXO problem
The port goes off-hook as it should but... dead air! I did try moving the cables and the problem would not really move with the line, it is kind of random. The only way to solve it disconnecting the cable and connecting it again.
I am pretty sure is the Provider's Adtran but I can't porve it.
Is there any way I can test the current, or Voltage, of the line when it's in this weird state ?
Joan
182
