Weird loggs messages in gateway 3925
End user has a 3925 router as a gateway with c3900-universalk9-mz.SPA.151-2.T4.bin IOS. Router is working  but I don´t understand why these messages appears.
is there any problem with hardware or is something wrong with IOS???
Sub Called(TON=Unknown, NPI=Unknown, Data=, Length=68)
   Sub Calling(TON=Unknown, NPI=Unknown, Data=?|, Length=19)
   Sub Called(TON=Unknown, NPI=Unknown, Data=, Length=84)
   Sub Calling(TON=Unknown, NPI=Unknown, Data=,PB, Length=1)
   Sub Calling(TON=Unknown, NPI=Unknown, Data=,P, Length=1)
   Sub Called(TON=Unknown, NPI=Unknown, Data=, Length=6)
   Sub Calling(TON=Unknown, NPI=Unknown, Data=,HB, Length=1)
   Sub Calling(TON=Unknown, NPI=Unknown, Data=,H, Length=1)
   Sub Calling(TON=Unknown, NPI=Unknown, Data=,H^W;lH^A[,X^Fdl ^A[,pB, Length=1)
   Sub Calling(TON=Unknown, NPI=Unknown, Data=?|B, Length=19)
1 ACCEPTED SOLUTION
Blue
You need to upgrade your IOS to resolve this cosmetic issue.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtl56898
Ronak Patel
Please rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hall of Fame Super Gold
Can be some cosmetic bug. Maybe the TAC knows about it.
Blue
Ronak Patel
Hi Ronak,
Thanks a lot for this info.
regards
981
