Werid one-way audio between ITSP and CUBE
Hi, I have a SIP trunk setup between C2801 cube and ITSP, ITSP gave us 4 IP addresses that will be involved in signalling and media source, so I configured the following ACL to limit outside access to my CUBE's IP 172.24.34.5
  10 permit ip host 172.24.0.97 host 172.24.34.5 (50  matches) <== 172.24.0.97 is ITSP's softswtich
     15 permit ip host 172.24.0.98 host 172.24.34.5 (3527 matches) <== 172.24.0.98 is ITSP's media source
     20 permit ip host 172.24.0.113 host 172.24.34.5 (173 matches) <== 172.24.0.113 is ITSP's softswtich
     30 permit ip host 172.24.0.114 host 172.24.34.5 (46604 matches) <== 172.24.34.5 is ITSP's media source
Once the above ACL is applied on ITSP's inbound interface, voice signalling is fine, but I always have one way audio -- audio from ITSP side can not be heard, ACL counters (for media) keeps incrementing normally during a call which means audio packets from ITSP are coming in. After I take off the above ACL from the physical interface facing ITSP's CPE, two-way audio resumes. SIP signaling debug confirms that there are only above ITSP's IP addresses are involved during a call.
What's up with this ACL?
Jian
Everyone's tags (4)
1 REPLY
Re: Werid one-way audio between ITSP and CUBE
I modified the ACL is a little bit, seems that there are traffic coming in from other source IPs from ITSP side.
Extended IP access list SIP_ITSP
    30 permit ip host 172.24.0.114 host 172.24.34.5 (50852 matches)
    40 deny udp any host 172.24.34.5 eq 5060
    50 permit udp any any (745 matches) <====== ?
This is the "show sip call" output of the call leg between ITSP and CUBE:
SIP UAC CALL INFO
Call 1
SIP Call ID                : 316F0C70-86DB11DF-8781D7D1-940D417B@172.24.34.5
   State of the call       : STATE_ACTIVE (7)
   Substate of the call    : SUBSTATE_NONE (0)
   Calling Number          : +441189090554
   Called Number           : 0014082030523
   Bit Flags               : 0xC04018 0x100 0x80080
   CC Call ID              : 901
   Source IP Address (Sig ): 172.24.34.5
   Destn SIP Req Addr:Port : [172.24.0.113]:5060
   Destn SIP Resp Addr:Port: [172.24.0.113]:5060
   Destination Name        : 172.24.0.113
   Number of Media Streams : 1
   Number of Active Streams: 1
   RTP Fork Object         : 0x0
   Media Mode              : flow-through
   Media Stream 1
     State of the stream      : STREAM_ACTIVE
     Stream Call ID           : 901
     Stream Type              : voice+dtmf (0)
     Stream Media Addr Type   : 1
     Negotiated Codec         : g711ulaw (20 bytes)
     Codec Payload Type       : 0
     Negotiated Dtmf-relay    : rtp-nte
     Dtmf-relay Payload Type  : 101
     Media Source IP Addr:Port: [172.24.34.5]:18588
     Media Dest IP Addr:Port  : [172.24.0.114]:12280
1706
