WFO /QM
I am looking at a "record all calls" option for ipcc express and just wanted to check that QM has this ability?
is there a seperate licence for this option?
also does it only work with agent phones or can you use it on non agent phones?
can you use QM without WFO?
thanks
1 REPLY
Super Bronze
Re: WFO /QM
QM and WFM are seperate products, so you can use one without the other.
QM will record all agent calls - it basically monitors the phone and starts recording whenever a call is made or received.
You install a QM client on the workstations, and then the users from UCCX are synced in. You have to configure the users's workstation logon name (i.e domain/user) for each user if you aren't integrated to AD, otherwise that should be populated automatically.
I didn't actually try adding a non-agent user to the system unfortunately.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
340
