What 2621 IOS version supports E&M cards?
I don't know if this is the right forum, but I wanted to find out if anyone knows what IOS feature set and version supports installing an E&M card in a 2621 router.
Thanks!
Hall of Fame Super Gold
Re: What 2621 IOS version supports E&M cards?
Any IOS with voice support whould support E&M cards also.
OK, But I need to know the specific feature set that supports it so I can get the right one.
Thanks!
Thanks!
That in turn depends on the IOS version. Use the feature navigator to find out all these things:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Thanks for the reply. Yes I tried that, but support for the E&M vic card is not listed as a "feature" :(
Any other ideas?
What I was telling you before, any "feature set" that supports voice/voip/anything related, supports E&M as well.
135
