What CUCME 7.X support new IP phones 6900 series?
What is the first callmanager express version with support the IP phones 6900 series
1 ACCEPTED SOLUTION
Re: What CUCME 7.X support new IP phones 6900 series?
None, support will be on 8.X
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Javalenc
what is the ios version i need load to my gateway 2821 to run CUCME 8.0
Hall of Fame Super Red
Hi there,
Just to try and fill Java's large shoes for a moment;
Cisco Unified CME 8.0 Supported Firmware, Platforms, Memory, and Voice Products
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme80spc.htm
IOS - 15.0(1)XA
Cisco Unified CME and Cisco IOS Software Version Compatibility Matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Hope this helps!
Rob
271
