07-02-2014 05:47 PM - edited 03-16-2019 11:17 PM
What happens to a registered phone that is unregistered for more than three days. I was told that they change state on callmanager?
Can anyone clarify what happens to a ip phone that is registered then eft unplugged for more than three days?
Solved! Go to Solution.
07-02-2014 06:23 PM
As per the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/6_1_1/rtmt/611-rtmt-admin/rtcallm.html
"By configuring the RIS Unused Cisco CallManager Device Store Period service parameter for the Cisco RIS Data Collector service in Cisco Unified Communications Manager Administration, you can configure the period of time that the RIS database keeps information on unregistered or rejected device."
Default: 3
Minimum: 1
Maximum: 30
Default is 3 days. After 3 days the phone status becomes "Unknown".
Manish
07-02-2014 06:23 PM
Default: 3
Minimum: 1
Maximum: 30
Manish
07-02-2014 08:26 PM
Manish thank you so fast of an answer I thought it was set higher but maybe someone altered it..In al the years I never noticed that change.
Again 5 Stars for you
