Community Member
what i need to use ip telephone
Hi , i need information
what i need to do working in my red ip telephones ?
thanks
2 ACCEPTED SOLUTIONS
Re: what i need to use ip telephone
You need call control, CME or CUCM. You can user an ISR for CME or a UC500.
A switch to which connect the phones and if necessary a router as a GW and to perform routing.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
I'd recommend you to engage a reputable partner so you can fully explain them what is the purpose and what requirements you need so they can guide you and create a solution for your needs.
If you're already with a partner you can call our partner helpline team and they'll be more than happy to assist in putting together a solution for you and tell you what PNs you need to order.
java
java
java
java
Community Member
ok thks, can you help me chose equipment to build like
22 ip telehons workstatio
ns
thks
java
java
Community Member
ok, I live in ecuador, can you help me with tecnical support and sale in my country ?
Hall of Fame Super Red
Hi Gregorio,
The Cisco Partner locator will help in this search
http://tools.cisco.com/WWChannels/LOCATR/performBasicSearch.do
Cheers!
Rob
265
