What is a suitable CME for c2691-ipvoicek9-mz.124-13b
Running a 2691 router.. checked the CME & IOS matrix but couldnt determine the correct CME to use for this
Can someone please advise?
Just going to be running some standard phones on this
Thanks in advance.
1 ACCEPTED SOLUTION
No it wont.
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
I think it will be CME 4.
You can check it by yourself.
Config t#telephony-service
Cntrl+z
show telephony service
You can see right there  CME version your IOS support.
Manish
Thanks for your reply Manish.
Doing that command gets invalid command unfortunately Manish.
I will reply with a sh ver soon
Hi Manish,
cme_router(config)#sh telephony?
% Unrecognized command
cme_router(config)#exit
cme_router#sh tel
Mar  1 08:17:32.195: %SYS-5-CONFIG_I: Configured from console by admin on consoleephony ?
cme_router#sh telephony
% Invalid input detected at '^' marker.
cme_router#
cme_router#
cme_router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
cme_router(config)#telephony-service
cme_router(config)#
me_router#sh ver
Cisco IOS Software, 2600 Software (C2691-ENTBASEK9-M), Version 12.4(13b), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Tue 24-Apr-07 15:32 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r)T, RELEASE SOFTWARE (fc1)
cme_router uptime is 1 hour, 40 minutes
System restarted at 16:28:02 14:54 Fri Mar 1 2002
System image file is "flash:c2691-entbasek9-mz.124-13b.bin"
Hope this helps
Its look like you are testing CME on GNS3 ?
Manish
Hi Manish,
Thanks for your reply.
No. Never used GNS3
Go with this one :
c2691-ipvoicek9-mz.124-15.T14.bin
Br,
Nadeem
Thanks Nadeem,
I have c2600-ipvoicek9-mz.124-15.T14.bin
Would that do?
No it wont.
Br,
Nadeem
Thanks Nadeem,
Will try this. May take about 4 days as internal router at home is dead. Have to replace it.
338
