02-08-2010 06:45 AM - edited 03-15-2019 09:21 PM
Hi all,
I have seen "%" sign used in IOS voice translation rules, but I can't find it in any translation rule config guides. What does it mean and how to use it?
thanks
02-08-2010 10:52 AM
02-08-2010 10:56 AM
The guide above is about the BTS product, not IOS.
To my knowledge, % is not used in translation rules.
02-08-2010 11:09 AM
Just to add to Paolo's note
Note Wildcard symbols such as the period (.), asterisk (*), percent sign (%), plus sign (+), and question mark (?) are not valid in translation rules. The router simply ignores these symbols when converting a number if they are used in a translation rule.
http://www.cisco.com/en/US/docs/ios/12_2/voice/configuration/guide/vvfpeers.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
02-08-2010 09:07 PM
appreciate your link and quote, but I got this doc from Cisco:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Wildcard | Definition |
. | Any single digit |
0 to 9,*,# | Any specific character |
[0-9] | Any range or sequence of characters |
* | Modifier—match none or more occurrences |
+ | Modifier—match one or more occurrences |
? | Modifier—match none or one occurrence |
it has no reference to %, but it does say * is valid, however from Javalenc's link, * is invalid??!! same with the period "." Is this because one is voice translation rule and the other is translation rule? I thought they do the same job, just voice translation rule is newer feature.
02-08-2010 09:27 PM
just found another doc that has % in translation rules ( towards the end of it):
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805b6f33.shtml
02-09-2010 02:53 AM
Even Cisco documents may contain errors.
You can use the feedback form on the left to notify Cisco and have it corrected.
