What is the best solution for CCM 4.1 (6) trunk?
How can I trunk CCM_A cluster to other CCM_B cluster? Is SIP trunk good? Or I should use something like Inter-cluster trunk?
What is the best solution?
The bandwidth from side A to Side B is about 30 Mbps.
Re: What is the best solution for CCM 4.1 (6) trunk?
both would work but an ICT non-GK controlled is the standard way to do this and is easier to troubleshoot than a SIP trunk if needed.
java
if this helps, please rate
java
www.cisco.com/go/pdi
And if this trunk will not be permanent? I purpose that there will be a lot of situations of make this trunk down. In this situation which solution is better?
104
