What is the best way integration Avaya S8710 and CUCM 7.1
ibmrmunayco
Hi Guys
I need integration Avaya S8710 and CUCM 7.1, in yours experiences which is the best way of integration, can you give me links o documentation ?
Thanks for you help
Gajanan Pande
Roberto,
You can find the CUCM - Avaya integration documentation here http://www.cisco.com/en/US/solutions/ns340/ns414/ns728/networking_solutions_products_genericcontent0900aecd805b561d.html
Pls rate the post if it helps.
GP.
Roberto,
I would definitely recommend SIP integration if you can do this on Avaya, it may need additional hardware and/or license though. From Cisco's perspective if you are going to use SIP I would recommend upgrading CUCM and take advantage of QSIG over SIP which will provide native QSIG features over SIP protocol, i.e. tromboning prevention, etc.
Chris
Hi Chris,
Which version do you recomend?
Thanks.
Chris Deren
8.5 or 8.6
