what is the command to check if there are any active calls before restarting the voice router?
what is the command to check if there are any active calls before restarting the voice router? thanks
Hi.I can suggest show call
Hi.
I can suggest show call active voice or show voice call status or show sip-ua call brief in case of SIP TSP.
Regards.
Carlo
Please rate all helpful posts "The more you help the more you learn"
thanks very much
thanks very much
50
