01-05-2018 05:28 PM - edited 03-17-2019 11:53 AM
I am trying to find an answer to this question, We have just started looking after a remote site, that has 7960 and 7941 SIP phones that are registered to an external SIP (asterisk) server.
The phones IP addresses are Natted on a Cisco 897 thru to the Internet. Now the 7960s work ok. But the 7941s cannot receive calls just make calls. I have searched for a definitive answer to why it is not working but have not found one.
looking at the ip nat translations below there are many more for the 7941 compared to the 7960
the .2,3 and 4 are 7960 and .5 is a 7941, all 7941s have a lot of entries
Any help appreciated
udp 49.xx.xx.xx:1032 10.xx.xx.2:5060 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:1024 10.xx.xx.3:5060 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:1139 10.xx.xx.4:5060 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:19224 10.xx.xx.4:19224 110.xx.xx.xx:15204 110.xx.xx.xx:15204
udp 49.xx.xx.xx:19226 10.xx.xx.4:19226 110.xx.xx.xx:19228 110.xx.xx.xx:19228
udp 49.xx.xx.xx:19228 10.xx.xx.4:19228 110.xx.xx.xx:14256 110.xx.xx.xx:14256
udp 49.xx.xx.xx:1037 10.xx.xx.5:5060 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:1036 10.xx.xx.5:49158 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:51673 10.xx.xx.5:51673 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:51674 10.xx.xx.5:51674 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:51675 10.xx.xx.5:51675 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:51676 10.xx.xx.5:51676 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:51677 10.xx.xx.5:51677 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:51678 10.xx.xx.5:51678 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:51679 10.xx.xx.5:51679 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:51680 10.xx.xx.5:51680 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:51681 10.xx.xx.5:51681 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:51682 10.xx.xx.5:51682 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:51683 10.xx.xx.5:51683 110.xx.xx.xx:5060 110.xx.xx.xx:5060
udp 49.xx.xx.xx:51684 10.xx.xx.5:51684 110.xx.xx.xx:5060 110.xx.xx.xx:5060
01-05-2018 09:01 PM
I have been going thru a capture done on the 897
the difference I see in the SIP registration is that the 7960 has "user=phone" whereas the 7941 has nothing
Is this the reason the 7941s can't receive calls. everything else in the capture looks much the same
01-05-2018 10:50 PM
Is the 897 acting as a pure router/FW only? A Wireshark trace (LAN and Internet), more info on setup and SIP messages from Asterix side would be handy to help troubleshoot. Are you expecting both phones to ring at the same time ?
How does Asterix know to send inbound call to correct phone eg 7941? Do you have a one-to-one NAT for both phones or some differentiator?
What happens if you only register the 7941 and keep 7960 unplugged and cleared from NAT table/ SIP registration etc ? Will the 7941 work in these circumstances?
01-05-2018 11:23 PM
01-06-2018 02:03 AM
So you cannot even call from 7960 to 7941 models?
OPTIONS are capabilities type query but in the limited messages provided, hard to put into context.
There are differences in these old models where 7960 is Type-A and does not support SIP-KPML or "+" dialing whereas 7941 do and some other differences eg with/without SIP dial rules configured on these phones.
01-06-2018 03:13 AM
01-06-2018 03:25 AM
What does SIP trace from attempted call look like ?
01-06-2018 03:39 AM
