08-11-2008 01:22 PM - edited 03-15-2019 12:32 PM
I look in the IOS Cisco Feature Navigator and found the the highest it would support is
CallManager Express 4.0(3)
is this correct?
I also was hoping to buy a 512MB CF card from the store a putting it in the router will it support more then 128? the hardware specs say 128 but its just a CF card?
Solved! Go to Solution.
08-11-2008 01:55 PM
The latest CME is 7.0(1), which jumped right from 4.3
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeroad.html
You cannot use the non-cisco CF in Cisco routers. You can get them to work if formatted properly, but they will not be supported.
HTH, please rate all posts!
Chris
08-11-2008 01:55 PM
Chris
08-11-2008 04:22 PM
So.... They work then if you format them correctly this is just for a lab anyways nothing production...
and by supported you mean cisco would not have anything to do with it correct?
08-11-2008 04:28 PM
You got it!
Chris
