What is the newest CCME I can put on a 2801?
I look in the IOS Cisco Feature Navigator and found the the highest it would support is
CallManager Express 4.0(3)
is this correct?
I also was hoping to buy a 512MB CF card from the store a putting it in the router will it support more then 128? the hardware specs say 128 but its just a CF card?
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: What is the newest CCME I can put on a 2801?
The latest CME is 7.0(1), which jumped right from 4.3
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeroad.html
You cannot use the non-cisco CF in Cisco routers. You can get them to work if formatted properly, but they will not be supported.
HTH, please rate all posts!
Chris
Chris
So.... They work then if you format them correctly this is just for a lab anyways nothing production...
and by supported you mean cisco would not have anything to do with it correct?
You got it!
Chris
99
