What is the procedure of Call Manager upgrade from version CUCM 7.1 (MCS Server) to version CUCM 10.2 (on UCS server)
What is the procedure of Call Manager upgrade from version CUCM 7.1 (MCS Server)  to version CUCM 10.2 (on UCS server) , please let me know the steps to what would be the backup procedures and upgrades.
Gaurav
Everyone's tags (1)
1 ACCEPTED SOLUTION
I'd suggest reading this
I'd suggest reading this guide to make sure you have prepared your environment to support 10.x first. The link below also contains the upgrade path to 10.0(1).
One of the ways you can do this is:
1/ Apply refresh upgrade cop file on all servers in cluster.
2/ Upgrade the cluster to 8.6(2). Take a backup of the cluster.
3/ Build a cluster of 8.6(2) servers on VMs, and assign them the same hostnames and IP address as the hardware cluster. (You may need to keep these on a separate network until switching off the hardware machines)
4/ Restore the backup taken from the hardware cluster on to the VM cluster.
5/ Upgrade VM cluster to 10.0(1).
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/upgrade/10_0_1/CUCM_BK_U4214F9D_00_upgrade-guide-cucm-100/CUCM_BK_U4214F9D_00_upgrade-guide-cucm-100_chapter_010.html#CUCM_RF_UA60AFAB_00
VIP Purple
Hi Gaurav,you can also refer
Hi Gaurav,
you can also refer the link
https://supportforums.cisco.com/discussion/12103966/ask-expert-cisco-unified-communications-manager-cucm-version-100
https://supportforums.cisco.com/video/12116751/prime-collaboration-deployment-concept
[+5] to Sreekanth and Jaime.
regds,
aman
Thanks guys for the
Thanks guys for the information
You might want to look into
You might want to look into prime collaboration deployment as well to make it easier, assuming you meet the ESXi license requirements.
java
if this helps, please rate
www.cisco.com/go/pdi
VIP Gold
PCD is the perfect tool for
PCD is the perfect tool for such migration.
Suresh
Hi,We're trying to document a
We're trying to document a complete process where you use your new BE or other UCS hardware (we're using C-Series) to build a "Jump Lab" where you can virtualize and upgrade your cluster without touching the production environment.
The overview of this process is here:
http://www.ashbridgesbay.ca/jump-overview
This is based on numbers of excellent Cisco presentations but is not "official" Cisco. Maybe this will help. We should have everything complete including videos of the different parts of the process in a week or so.
Joey
joey@ashbridgesbay.ca
as per the the process
as per the the process defined "Jump Upgrade" from 7.1.3 - CUCM 8.6(2) and we select this process instead of PCD approach in case the current MCS HW does not support the 8.6(2) HW requirement then can we go for the given below steps:
CUCM 7.1.3 upgrade to CUCM 7.1.5( on the same MCS server) take the DRS backup
Install VM and install CUCM 7.1.5( which is not supported but a intermediate version for upgrade to 9.X or 10.0)--> UPgrade to CUCM 10.0 --> take the DRS backup ---> recreate the VM's as per 10.0 OVA again --> restore the DRS backup which we have taken in last to last step.
is this is the perfect approach?
Jump upgrade is only allowed
Jump upgrade is only allowed when upgrading to 9.1(2), all info on the procedure is here
https://communities.cisco.com/community/partner/collaboration/migration
But yes, those are the major steps, just bear in mind that if you want to go to 10, you would need to then upgrade again after the DRS restore on fresh installs.
java
513
