What is the reset sequence on a 7961?
What is the reset sequence on a 7961?  This is for just a reset, not a reset to factory defaults, just reset the phone?  Thanks.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: What is the reset sequence on a 7961?
Assuming SCCP/Skinny load on the 7961, would suggest to go to Network Config via phone menu
first and then try entering **#**
Hall of Fame Super Red
Hi Anthony,
Press Settings Button then **#**
Cheers!
Rob
Thanks Rob, I did that sequence but it just doesn't reset the phone.  There may be something else going on then.
   Anthony
Yes, that did it.  I went to the Network Configuration and did the sequence, it reset.  Thanks.
Setting > **#** works, you just need to press the digits quickly
808
