Community Member
What is the size of hardware queue on Ethernet interfaces?
Hi guys,
Does anyone know the size of hw queue on ethernet interfaces and how you can change it?
I have a 2811 router and I am trying to find out what is the size of its fastethernet hardware queue. I issued the command "sh controllers fastEthernet 0/0" and part of the response is :
Tx Rings
Tx Ring 0                         Tx Ring 1
  - size        = 256              - size        = 0
  - head        = 125              - head        = 0
  - tail        = 125              - tail        = 0
  - usedtxds    = 0                - usedtxds    = 0
  - framecnt    = 0                - framecnt    = 0
  - shadow      = 0x46EF4D80        - shadow      = 0x00000000
  - ring        = 0x0F1B63E0        - ring        = 0x00000000
  - ring_malloc = 0x3F1B63E0        - ring_malloc = 0x00000000
  Tx Ring 2                         Tx Ring 3
  - size        = 0                - size        = 0
  - head        = 0                - head        = 0
  - tail        = 0                - tail        = 0
  - shadow      = 0x00000000        - shadow      = 0x00000000
  - ring        = 0x00000000        - ring        = 0x00000000
  - ring_malloc = 0x00000000        - ring_malloc = 0x00000000
  Tx Ring 4                         Tx Ring 5
  Tx Ring 6                         Tx Ring 7
As I can see fom this command the size of the hardware queue should be 256 packets (Am I right? Is this the right command to see?).
I have changed the queuing method on this fastethernet interface form the default, fifo, to wfq and also llq. When I reissued the command "sh controllers fastEthernet 0/0" nothing changed in the output. I tried also changing the depth of the hw queue manually by typing  "tx-queue-limit 20" and still nothing changed.
This is my conf on this interface:
interface FastEthernet0/0
bandwidth 512
ip address 10.1.120.110 255.255.255.0
tx-ring-limit 20
tx-queue-limit 20
duplex auto
speed auto
service-policy output Voce
end
Thanks for the help.
1 REPLY
Re: What is the size of hardware queue on Ethernet interfaces?
router has 2 type of Queues:
The Hardware Queue which is always FIFO, and the Software Queue determined by any Queuing Strategy to hold the packet.
Tx-ring limit defines the number of packet stored on the Hardward Queue before leaves a router.
see here for more info:
http://www.cisco.com/application/pdf/paws/6142/txringlimit_6142.pdf
You should not have to mess with this at all on an ethernet interface -
you should use the show policy-map xxx int x/y   command to view how the service policy is working.
Here is the QOS design guide for your reference:
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoS-SRND-Book.html
Hope this helps,
Chester
2148
